Spacers on stock SVT wheels
4.1K views 8 replies 5 participants last post by  Flying56eagle
#1 ·
Anyone running any spacers? Ide like to flush up the rear alittle bit. Anyone got any pictures and the amount of spacer you are running? I did some searches bu t didnt find much. Thanks!
#2 ·
When I bought some used Rota's, they came with a pair of 5mm spacers. I mocked them up on the car and noticed the lugs had less to thread onto so I sold them. Just wondering if you might need to put in longer studs to accommodate a larger distance for the wheels.
#4 ·
after you get longer studs you can use 5mm spacers with no problems. if your lowered, i would go any wider than that. the SVT wheels have a 49mm offset. the 5mm spacers will give them the look of being 44mm offset. i believe you can go as far as 42mm of offset before you run into rubbing issues. this of course is on a lowered focus.
im on Tien S-Techs
i have a 42mm offset
i dont rub!
take a look in my gallery for this combination
#8 ·
Should be cheap and easy to do so, hopefully have this rolled out with some spacers by spring so I can get these winter wheels and tires off here and put on my re-finished SVT 5-Spokes. Thanks for the info guys.
