ready to boost! (56k got some time)
3.6K views 38 replies 23 participants last post by  07FocusST
#1 ·
So after a few months of collecting parts i finally have everything ready to put my new built engine in [:)]. The motor has eagle rods, supertech 8.7:1 pistons, fr head, focus central cam gears, crower stage 2 turbo grind cams, massive pulleys and Massive MSX 90 Performance Ignition, motorcraft colder plugs, and 180 degree thermostat. I also have the new htp performances intake manifold on its way soon i hope, all three vf motor mounts, torsen lsd,
cm stage 4 six puck, Fidanza Lightweight Aluminum Flywheel, 3 gauge pillar pod, aem wideband, and autometer egt, oil pressure, and boost gauge, and a custom vacuum manifold. This is getting all installed this weekend, and hopefully soon the massive speed system turbo will be going in and soon and then ill be on my way to 350 [headbang]. Here are some pictures, let me know what you think.
Here is a picture of my car and the motor when i picked it up this weekend at Massive. It has their turbo manifold and a turbo they had sitting around mocked up on it.
#3 ·
hmmm... a lot of those parts look familiar [;)]
good luck on your quest for 350hp. hope we are both successful. what turbo are you using?
#6 ·
compression
What’s your goal for boost? Your compression is so low when you’re not in boost the car will make no power till 3500-4000. Just something to think about if you over looked that. I think that’s where tom was going with his questions. One more thing.. I see you have BAP what are some of the other ways you going to handle fuel management? Everything looks good just needs a good tune.
#8 ·
holy shit did you win the lottery or something! wow!
#9 ·
Low compression is very streetable.
A perfect example.
Focus RS has 8.0:1 CR
Ford lightning 8.4:1
8.7 is not low.
#15 ·
If you don't mind... what would someone expect to pay for all of the mods you listed ASIDE from the turbo and labor? And basically they will give about 125 extra hp and torque over just a turbo on a stock engine?
#26 ·
We started on saturday morning and worked until midnight sunday, and its done. It was a pretty smooth install only had a few bolts we couldnt get out, and the axles were a pain because one of them, the threads got kinda fouled up. We dropped the motor out of the bottom of the car and that seemed to work really well. Here are some pictures of the process.
Here is where we started saturday morning
They only snag we had as far as getting bolts out was one of the posts on the ac, so being a good mechanic i just cut it out [:D]
We got it out and the motor and split the trans and found something interesting
The stock diff was missing teeth and the collector magnet was covered in big chucks of metal.
This is where we ended saturday night
Figured it would be the only time i could stand in my engine bay [:)]
Now the motor was dressed and it was time to be put back in
Rally Focus
25 hours later it was back in and running
If anyone is doing this soon and has any questions shoot me a pm and ill give ya some more details and the tricks we found along the way.
#29 ·
awesome....i need and engine like that.....
oh and the photo where ur cutting something is pretty gross.......hint: wear some pants haha
