Hi I have a 2002 petrol 1.8 16v zetec that recently had the cam belt go taking out most the car with it, so had the usual done.. new valves/head skim/gaskets/Cam belt and injectors. The car seemed to drive fine for a while then one day I noticed all coolant was suddenly gone, so had the thermostat changed and now the CEL is on (reading P0300 Cylinder misfire no#4) and the car has lost power especially at 2000rpm in 4/5 gear and does no want to pull going up hill (CEL will flash but stops on comming down hill). Tried new plugs HTs and Coil pack but still apparantly misfire on cylinder four ? While going through all the work that had been done on the car before I owned it I have found an Emissions test that has a note on bottom saying..
Engine speed measurement - bypassed
Engine oil temp sensor - bypassed
Could this be part of the problem if the Garage have installed everything as it should be without them knowing about the possible bypass ? also since the thermostat was changed I have found a Black/Orange line wire with a connection on the end with a Yellow centre [dunno], it seems to run from across the left top side of the engine to the right hand side across the top and would only seem to reach as far as the thermostat or Fuses/Relay boxes or maybe behind minfold just the one wire on its own, I have had a look at the Relay box and it looks as if an entire row of relays is missing [screwy] any ideas would be much appreciated either on the wire or the possibles for the misfire reading TY
