of course, no less than 2 weeks after having my ZTS back to normal, i'm getting dangerously high temps when idling.
Couple things to point out. Temp is fine when on highway or accelerating...in fact, I noticed it for the first time Tuesday when I was parallel parking. Then I sat in the parking spot and pressed the accelerator gently for 20 seconds or so and it cooled back down.
Second thing, the first time it happened, Tuesday, the temp was just a little above normal. Today it was nearly in the red. Whatever the issue, seems to be getting worse. Strangely enough, no check engine light or any warning light comes on when it happens. Shouldnt it be??
From doing some research here, this is the game plan:
I checked coolant level, seems ok..no leaks either
Tomorrow, gonna check the fuse for the fans
Also, gonna check the mixture, I believe an improper mixture could cause an improper reading on the temp gauge. I doubt this is the problem, but worth a shot.
I've read about a temperature sending unit....where is it and how can I test to see if thats the issue?
Finally, is it safe to drive this vehicle at this point? Since the coolant level is ok and theres no leaks, I dont know if it can get to a damaging temp or not. Thoughts??
Thx in advance...you guys were VERY helpful last time around.
