Over Reving Problem
1.3K views 12 replies 8 participants last post by  FiFoci
#1 ·
Ok i have MSD Ignition,OBX Headers,Cold Air intake,Magnaflow exahust,and 65mm TB and now i have a over reving problem... it started when i put the throttle body on ... i need help i tried everything except putting a tune on it... over revs so much when i put it into gear i jerks really bad in drive and reverse... i need help
#13 ·
did u disconnect the battery when u installed the TB? mine did this and i reset the ecu and it was fine. also make sure the tps is in the right holes. my FC 65 has 2 set of holes for 03' and 00'-02'
