The engine is a 2.0L 16V DOHC.
parts recently replaced to include
clutch slave cylinder
clutch master cylinder
Alternator
main power cable from alternator, starter, battery
Lower control arms on both sides
front brakes
The engine ran fine prior to needing a slave cylinder replacement for the clutch. While ripping apart the engine bay for the transmission to be freed it was noticed the main system cable needed to be replaced as it was in very poor condition. The brakes and lower control arms were replaced due to age. The alternator was replaced due to age.
current condition is the car is put back together and is now in a no-start condition. Will start with starter fluid but dies.
key cylinder turned to the on position you can hear the fuel pump prime. The pressure reading from an inline gauge is 42 psi to 50 but settles to 42.
The starter engages and turns over successfully.
Spark plugs all have sparks. The Cylinders appear dry.
Fuel injectors show battery voltage on one pin and ground on the other. I do not have a scope I can't see the occilation. Going to attempt a stethoscope to hear the injector turning on and off
What device is prohibiting the fuel rail from opening? Is there a vacuum hose or something I missed? I had to clear a couple of dirt dobbers from a couple of my 1/8 lines but they appeared to be passing air after cleaning looking for a point in the right direction.
Alternator
front brakes
