Car: 2002 SVT Focus #4494
I have lost power steering but there are no visible leaks anywhere. My mechanic and I checked the entire system with a flashlight and the car on a lift.
There are no visible signs of fluid leakage on pressure line or return line hoses or fittings at rack or pump. There are no signs of leakage behind the pulley near shaft on pump.
Symptoms began after a few seconds at WOT at redline. Maybe I should have shifted in to sixth gear.
My best guess is old fluid, combined with high RPM and engine load, killed a fitting. This could have let air in to the system--increased temperature in the system--and the heat killed the pump.
I ordered an OEM HBD-HT power steering pump from Tasca but have decided to replace the high pressure line as well.
Has anyone had a pump fail before without any leaks?
And which power steering line do you prefer? Gates? Edelman? Ordered from c-f-m?
