So, iv had a 02 svt sitting around for some time now. I pulled it out today and decided to drive it a little. Well some (ALOT) of teeth broke off the timing belt while i was driving it. Got it back to the house tore it all down thinking im gonna have to remove the head and get new valves. Before i got to far i check the valve buckets. all were up and had spring pressure. So i found a timing belt i had laying around and put it on. real quick (half ass job) and it fired right up. It has a very rough idle but smooth if i rev it. I did a compression test and it was 120,120,120,120. Im 98% sure the cam timing is WAY off.
Here is my question. How do u set the cam timing on a SVT with that VCT Gear. I have done it many times before on zetec but never SVT. When i put the belt on i didnt know what to do with the VCT so i just lined up the cams and crank with the tools and installed the belt. Iv tried looking for a how to with no success. I got 3 codes when i started it
p0193,p1246,p1504
When the car was running it had no accessories (no belt or timing cover/motor mount) so im thinking those codes are low voltage related.
p0193,p1246,p1504
