Anyone know it? I need to rotate my tires.
I don't recall seeing it in the oener's manual.thefrush said:Owner's manual?
You should use a torque wrench.SVTmonkey said:hand tight (I mean with a wrench), just use the proper torquing sequence...
You don't need to use a torque wrench (have you checked the prices on these lately?), you will not have a problem if you use the supplied wrench and hand tighten. This isn't a commercial truck with a GVWR of 18000 kg. There's a reason why they don't clearly indicate a specified torque...cause you don't need to worry about it. Shops might have a guide, but that is for legality issues....product of a sue me society.bananabuggy said:You should use a torque wrench.
You would be laughed out of any self respecting paddock at the track.SVTmonkey said:You don't need to use a torque wrench (have you checked the prices on these lately?), you will not have a problem if you use the supplied wrench and hand tighten. This isn't a commercial truck with a GVWR of 18000 kg. There's a reason why they don't clearly indicate a specified torque...cause you don't need to worry about it. Shops might have a guide, but that is for legality issues....product of a sue me society.
I torque them by hand in the cross pattern until pretty damn tight and then use the torque wrench to finish it off.. I quit using a rattle gun years ago as they always eventually knock the chrome off nuts (the car, not mine). I always remove and reinstall by hand or an air ratchet. A little slower but worth it in the long run.WD40 said:I set the wrench to 10 lbs less than spec, torque, then set it to spec, and torque again.
You got it.[thumb]
As long as they are torqued in a "cross pattern" like the manual shows, and done evenly, you're set.
Though, I don't think it's absolutely necessary to torque them in steps like you would a head gasket.
With that said, I suppose I do do them in steps to some degree.
I use my air impact set at 80 ft lbs while the wheel is still in the air.
This insures the wheel is properly seated against the rotor.
Once I lower it to the ground, I pull out the torque wrench and go over them again at the proper setting.
Not to mention your brake man will love you. The biggest cause of warped rotors, IMHO, is improper torque at the wheelnut.bananabuggy said:You would be laughed out of any self respecting paddock at the track.
SVT comes stock with chrome bling nuts, i like themModemJunki said:Chrome nutz.....BLING![]
I usually deal with torque wrenches from commercial vehicles...truck tractors etc....they are really expensive, I didn't know torque wrenches for a car were cheap...there's honestly no need for them.bananabuggy said:You would be laughed out of any self respecting paddock at the track.
I was actually in the same boat...no torquing my lug nuts, and the last time i rotated, i used a really old "protractor looking" wrench that we had, it seemed like it was decently accurate, but not very well, atleast they are all equal or close to it now. If you buy a wrench, don't buy that style, get a clicking type.SVT4ME said:This is an interesting topic seeing as that I just rotated my tires myself today and did NOT use a torque wrench on the lug nuts. Using the supplied wrench in the trunk I tightened the nuts until I could feel resistance to moving further, being careful not to push hard or "yank" on the handle and exert too much force. Took the car for a spin around the block, rechecked the tightness, and everything seems okay (for now anyway). If you're not heavy-handed or ridiculously careless there isn't always a NEED for an everyday car to have the nuts torqued down to perfection. Notice I left the opening, though by saying "there isn't *always* a need?"
Sometimes there is, I know for example that the brakes on the Mk. I MR2 are VERY sensitive to uneven and/or over-torquing of the lug nuts. EXTREMELY common for them to have warped brake rotors, over and over again, if the nuts are too tight or tightened unevenly, in concert with the fact that the brakes on early MR2's were undersized and got worked hard and thus got very HOT. Man did I go through a lot of brake services on that car.
I dunno, as far as the Focus, I'm not real worried... I'll keep on eye on how the brakes feel (pulsing, uneven grabbing) and how the wheels feel in terms of balance but I'm not going to lose sleep over it.
