the stock intake is already very very efficient on the SVT and it is much less prone to heat soak than an aftermarket metal tubing intake. not to mention that it is impervious to hydrolock unless you try to drive through a few feet of standing water. on cold days the aem might make slightly more power than stock until the engine gets fully up to temp and the temperature of the engine bay and therefore the intake get good and hot. during the summer it might actually be worse than stock. cant say for sure on the last though since im no longer running a CAI on mine. ive wanted to run a ram air intake on mine for a very long time though. the SVT intake TB would point the intake tube right out of the engine bay if you were to cut a small hole in the hood. that would be an excellent intake in all but wet weather. no bends and short tubing length and cold air from outside the engine bay. you get the air velocity of a short ram intake and the cold air density of a CAI. THAT would be the best aftermarket intake for the SVT and i think all it would take to do it would be a MAF tube, silicone couplers, ties, some metal or PVC tubing, a way to brace the intake and a good cone filter. and a cutting tool to make a hole in the hood of course.
