I wrote this guide on XDA, but since this forum has helped me in the past, I figured it would be nice to give something back.
I thought it would be nice to distill all of the information provided in this thread: MyFord Touch Navigation Activation Only | Windows Mobile Development and Hacking into an easy to follow guide. This method was originally described here: https://www.drive2.ru/l/10018006/
Before you proceed, please understand the following:
What you will need:
Got everything? Let's get started:
Hopefully you now have access to a navigation system that is every bit as sub-par but adequate as the rest of the MyFord Touch system. Congrats!
UPDATE: Someone just told me that their car wouldn't read their map card until they installed the package that I labeled optional, so it might be worth a shot if you didn't use it and you're having issues.
- I am very new to modifications like this and I'm not very knowledgeable. If you mess something up, I probably won't be able to help you.
- The following guide is the steps that I took to get this working on my 2012 Ford Focus. I'm not aware of any car model-specific issues, but that doesn't mean that there aren't any.
- This guide is for North American cars. If you live in a different region this will still probably work, but you will need to use the MyFord Touch system software files that correspond to your region.
What you will need:
- Forscan (I used version 2.3.4 beta) from here: What's new
- An extended license for Forscan. Follow the instructions to get that here: FORScan forum ? View topic - Standard and Extended licenses for Windows
- An ELM327 OBD2 adapter that is compatible with Forscan. I used this one: ELM327 USB Auto Diagnostic Scanner: OBD Scan Tool for OBD2, OBDII Cars, Vans, Trucks
- This png file: https://yadi.sk/d/i-JGQR8ZwLrLM
- A USB flash drive
- MyFord Touch system software version 3.8 (also known as SYNCGen2_3.08.15128.EA.10_PRODUCT). This is the latest version as of this writing. If you aren't on it, you can get the North American update from here: http://ivsu.binaries.ford.com/swparts/Gen2v38build15128updatepackageNARev2.zip. Install it if you don't already have it.
- An SD card that contains the navigation maps. The latest version for North America is A7. The latest version for Europe is F5. You can use older versions if you like. Find them on eBay, or ask around for tips on how to not use eBay. I can't give you any more information than that without violating forum rules.
- OPTIONAL: These North American nav-related files: https://mega.nz/#!S9YhmYgA!iyRuCQab6CmDbWL0Pot-AkoThoYErQ5CNDTS9drZeSI. You only need these to avoid having to do a master reset. If you're okay with doing a master reset, don't worry about them.
- Plug (or pair, if you're using a Bluetooth adapter) your OBD2 interface into the OBD2 port on your car.
- Put your key in the car and turn it to the On position (the first click after off. Do not put it in accessory mode, which is the second click).
- Start up Forscan. You should be on the Vehicle and Interface Information screen (the icon looks like a car with an "i" in a yellow circle on top of it).
- Click on the icon that looks like two power cables plugged in to each other to connect to your car. You'll see some information start to populate the log. Wait until it is completely finished.
- Forscan might show you a menu with different vehicle options to pick. Pick yours from the list. In my case, it asked if my Focus was 2012 or 2013.
- If at any time Forscan asks if you want to save something so you can back it up later, say yes.
- Click on the icon that looks like a microchip and under the Configuration and Programming tab, select APIM and press the play icon.
- You'll see a lot of fields that are labeled with numbers that start with 7D0. Click the disk icon at the bottom of the screen to save a copy of these original values.
- Find 7D0-01-02 and change the first two numbers in the first field from 00 to 04. Click Write to save the change.
- You'll see a warning message about the checksum being bad. Click yes to ignore it and continue with the change.
- Go back to the Vehicle and Interface Information screen (the icon looks like a car with an "i" in a yellow circle on top of it) and click the unplugged power cables icon to disconnect your computer from the car. You can remove the OBD2 interface now if you like.
- Put the png file that you downloaded earlier on to a USB flash drive and plug it into the USB port in your car.
- In MyFord Touch, go to settings -> display, and find the setting for changing the wallpaper (I forget exactly what it's called).
- Click on Add, and select your USB drive. Highlight the png file, and in the preview box, you should see a blue button that says "enable nav" or something like that. Press it, and you should see "nav enabled" appear above it.
- If you're okay with doing a master reset, do that now and you should see the navigation functions when it's done. Look for the "i" icon that will appear to the left of the home screen icon on MyFord Touch.
- If you don't feel like doing a master reset, extract the package I labeled as optional to your USB flash drive and plug it in to your car. It will install some things (be patient, let it finish) and when it's done, you should see the "i" mentioned previously.
- Insert your navigation SD card into your car's SD card slot, and you should be good to go.
