Well my time has come for the pcv hose R&R as the car shows the symptoms. I will tackle the repair myself as it isn't all that hard. Reading up on things first I've decided to remove the cooling fan assembly only and then use the correct combination of extensions for the manifold bolts. This is actually the first issue the car has ever had.
Looking at the fans from under the car I am wondering about the trick in getting it out. Seems like it is hanging on 4 brackets and all one needs to do is lift up and drop out. Yet it also seems to have no room at all for lifting up as I just tried that. Rather than breaking a mount I thought I'd better ask first. In the meantime I do the timing belt/water pump change out on another car.
