First-time poster, compulsive forum reader. I have dual-zone climate control (not MFT), so this is regarding the digitized dials.
To start, I figure Ford is using the "AC" button literally (which is fine), as in conditioning air both colder or hotter. Given that ...
Regardless of whether Auto is selected, with AC "on" it will activate the heat if the car gets within an apparent 2 degrees of my target temp. Say the ambient temp is 85 and I set it to 80 (intending the only restriction to be "no warmer than 80"). Moments later, stopped in the shade or whatever, the ambient temp drops to 78 so the heat activates!
So, how does one disable heat while setting a cooling restriction? Failing that, how to circumvent such an unreasonably narrow (for me) target range? My only avoidance techniques are to constantly monitor, de/activate AC and/ or manually creep the temp in various directions, or to select a too-cold temp and wear a sweater (energy waste).
For whatever it's worth, I feel an easy-to-use system to allow for virtually any circumstance would be: Cooling on/off, Heating on/off, Circulate on/off, Fan speed, Zone selection, Auto (which activates cooling or heat, given a user-specified *range*). Basically, I guess I'm saying I want a more Boolean-style control system.
I must be missing something cuz I've found no other complaints anywhere ... thoughts?
