brake lights staying on when i put my headlights on
1 reading
42K views 13 replies 13 participants last post by  Geraldjboyer
#1 ·
can anyone help me with this problem when i put my headlights on all three of my brake lights stay on
#4 ·
I am currently having the same issue, The wires in the hatch were in poor condition so I fixed those but it has not corrected the issue. I guess I will go to the hazard switch and the brake swith from here. Any other ideas ?
Also would it be beneficial to replace the wiring for the hatch ? How labor intensive would this be ?
Thanks for all of the help.
#5 ·
Have you replaced any conventional bulbs with LEDs recently?
After I put too many LED bulb replacements in my 97 cougar when I turned the lights on 3rd brake light and everything stayed on. After I switched back to filament bulb everything went back to normal.
#7 ·
have you changed a brake light recently ? the brake lights and tail lights are combined if the wrong bulb is fitted it shorts causing the brake lights to light up try removing each bulb separatly when the lights are on and see if the other brake light goes out.
had this fault a few times its nearly always a bulb
