Hello Everybody,
First off I would like to say that I really enjoy reading this form, a lot of useful and concrete information.
I have found the following information in a Ford bulletin, posted by a member on this forum:
“Green clutches can lead to a rattle noise that sounds like a catalytic convertor shield rattle. This noise is commonly heard after light pedal 1-2, 2-3 or 3-4 up-shifts. This rattle noise will improve greatly as the clutch completes the break-in.”
I have a 2012 Ford Focus with the Powershift transmission. The car is a May 23, 2011 built. It was picked up August 1, 2011. To the best of my knowledge the cars in untouched, no TSB’s or any upgrades have been performed on it after the delivery date (I am not sure they did anything before they delivered it either)
My car has 8000 kilometers or 5000 miles.
I have had a small rattle like the one described by Ford since the car was new, it never intensified and it never went away. It starts after the transmission gets to operating temperature, it does NOT do it while it is cold at all.
It occurs mostly when the transmission is shifting up and the tachometer is passing 1,500 rpm in range to 2,000 rpm and then disappears; it sometimes re-appears if the revs fall in the range.
Since this occurs when the transmission gets worm or operating temperature and it never got worse is it normal? Is a small amount of rattle normal with these transmissions?
Thank you, any feedback is greatly appreciated.
