What do I want from the Tech/Spa day?
  • Yes. Tech, Spa, Food, and Fun.
    Votes: 9 53%
  • Yes. Tech, Food, and Fun.
    Votes: 4 24%
  • Yes. Tech, and fun.
    Votes: 1 5.9%
  • No. I am lame.
    Votes: 3 18%
21 - 40 of 221 Posts
Unfortunately, I cannot make it due to work constraints. I'm still fighting a very tight budget, but as soon as things relax, I'll definitely make it to some of these.
Ok, I have a table but not long [:(] But it's really thick [:D]
The duratec Header install is going to be a BEAR to install and I suggest that we have someone willing to help ME do it. The problem is getting it to fit (The firewall and heat sheilding is in the way) You will have valve cover scratches and a dented in firewall if we don't do it right, Maybe a write up or how-to instructions would be helpful, just bring a print out or instructions on how to do so. The NX setup requires some knowlege of wiring and relays (And how to hide Nitrous lines [}:)] But I'm sure we can accomodate you, There is another member that has wiring experience I'll need help there too.
Well guys lets get this thing off and running !!
on the 20th you guys can go to Focus Sport and dyno them bad boys CLEAN and hopefully FASTER !!
Troy. [thumb]
The duratec Header install is going to be a BEAR to install and I suggest that we have someone willing to help ME do it. The problem is getting it to fit (The firewall and heat sheilding is in the way) You will have valve cover scratches and a dented in firewall if we don't do it right, Maybe a write up or how-to instructions would be helpful, just bring a print out or instructions on how to do so. The NX setup requires some knowlege of wiring and relays (And how to hide Nitrous lines [}:)]) But I'm sure we can accomodate you, There is another member that has wiring experience I'll need help there too, I believe it's daredevil...... ??
Troy. [thumb]
^^ I double posted..... Huh ?? [confused] Oh well maybe a mod could delete the 1st one, I havn't installed an NX kit but I have done a Jackson Racing supercharger, A Vortech supercharger install.... It CAN'T Be any Harder than that .!!!
I can usually hook up a Lighting kit in about 2 hours, depending on what type it is and how high we can get the car jacked up. I'll only have to drill one hole for wiring and the holes for mounting, other than that, I know all of the nooks and spaces that I can run wiring. It's my specialty since I've done about 3 different ones on my car and another 3 one different cars.
Discussion starter · #36 ·
Yeah for sure. I am going to bring my GF. Thanks for being aware my wallet. I appreciate it. Bring who ever you guys want. You dont have to pay $10 per person just kick in some to make it even. My ultimate goal would be to break even at the end of the day.
