yes or not worth it
The 2001 FF is not even close to the 2012+ FF. From most users' experience, the GDI engines work better when higher octane gasoline is used.When I bought my first focus in 2001 I was used to running 93 in my escort GTs, so I got a "free" fillup at the station down the road from the dealer for buying it, filled it with 93, and the car wouldn't idle hardly at all. Went back to the dealer a couple of days later and one of the techs said, "let me guess, did you put something higher than 87 in it?" When I answered he said, "yeah these cars are tuned for 87 only, it'll run like shit with anything else." After that tank I switched to 87, problem solved. I would like a tune though n see if it doe any better with a tune for higher grade.
I feel ya (should I say I FUEL ya)Wow.... Even before my mods when I was running mid grade 89 with ethanol I got 43L/450km (10.5 km/l) mixed driving. 500km hwy.
And this is a 2.0L ZETEC in a 4dr, 5spd Mazda Tribute... not a Focus! Not sure why you guys are getting such low numbers... must be in the tune or the transmission.
TY 4 the input, there's always a light at the end of the roadYou only have about 800mi on your engine. It's still breaking in. When finally broken in, you'll start seeing a large improvement. Also, are you on the gas a bit more since the tune? What about your type of driving? More city or more highway? I know I was getting ~21MPG when my commute was less than 5mi. Now my MPG is around ~27-28 (Along with tons of hot rodding [cool]) now that my commute is 15mi. The stop and go of the city was really killing my MPG.
Ok I never drive the car over 60-70km/hIt all depends on driving conditions. If you have lots of stop-and-go, red lights, you'll see almost the same as you posted (a bit more, arround 9 km / L) This car is not good for short distances and heavy city trafic. I am at 8.2 L / 100 km in average since I bought the car and I am within EPA norm for 50-50 driving. Here we have the "winter fuell" which has a big influence on the MPG, but it is balanced by the summer time.
I have been saying that for a while now. I believe a lot of the DCT complaints, especially shuddering and stuttering, are misdirected and should actually be drivability issues related to 87 octane gas/ethanol.I'm convinced it's the gas that is causing stuttering etc.
Was driving around today, shuddering and lunging. Hasn't happened when I was on 93.
Sure the car is designed to run on 87. But it's clear not as efficiently. Even with the snorkel delete and intake resonator delete, it was lunging and shuddering.The car is designed to operate correctly on 87 or even e85 per the manual. If it isn't, that is not a gas problem, that is a powertrane problem.
Sent from my Galaxy Note 2 using FF Mobile.
Then explain how changing from 87 to 93 I see no issues. I go back, issues. [scratch]Efficiency is one thing, shuddering and lunging is something else entirely.
I don't think that Shell gasoline is cheap gas by any means. Now I see if I went down to some shady shop off of some shady road, sure. Next tank will be BP as AMEX is having an offer. 5$ credit for every 25$ worth of gas.Could also be the quality of the gas: not all gas is created equal.
My old Silverado would burn anything, no problem. Could probably drop rubbing alcohol in the tank and it would purr. But one tank of Arco, and I thought I was firing on 3/6 cylinders. I don't see how people could buy crap quality gas. Sure it's cheap, but c'mon, the extra 20¢ for a good brand is worth every penny.
Sent from my Galaxy S4 using magic
I've gotten a bad batch of gas before. I used to hit the same Chevron every fill up, and one time I just got a bad tank. Next tank was fine. Not really anything else you can do. Maybe toss some of the Lucas fuel system cleaner in? Can't hurt anything.Then explain how changing from 87 to 93 I see no issues. I go back, issues. [scratch]
Switched back to 87 since I was able to get it cheap. 93 Shell was 40c more. Screw that. It's becoming winter. lol.
Personally, I noticed a big improvement in throttle response and driveability with 93 octane vs 87 octane. 89 runs well, but doesn't seem quite as good as 93.I have been saying that for a while now. I believe a lot of the DCT complaints, especially shuddering and stuttering, are misdirected and should actually be drivability issues related to 87 octane gas/ethanol.
I think you are missing my point. I am not saying the gas is not making a difference for you. I am saying there is a flaw in these powertranes (or at a minimum fords specs for it) if it cannot perform correctly on gasoline that the manufacturer says the engine is intended to use.Then explain how changing from 87 to 93 I see no issues. I go back, issues. [scratch]
Using 93-octane pump gas (9% ethanol), the 5.3L belted out 307hp at 5200rpm and 332 lb-ft of torque at 4200rpm on LPE’s Dynojet 248 through the factory 6L80E transmission. This was good enough for 7.5-second 0 to 60mph times, and 15.94 at 90.7mph in the quarter-mile.
Taking advantage of the ’14 model’s Flex Fuel capabilities, LPE dumped in some E85 and repeated its tests. The on-board sensor read 65% ethanol content, with 1/8 tank of E10 diluting the mixture, when the dyno read 321hp and 355 lb-ft of torque. This certainly seems in line with GM’s 380hp crank horsepower rating when using E85 (355hp on gasoline) as well as the subsequent acceleration tests.
http://www.gmhightechperformance.com/tech/engines/1306_2014_silverado_solid_baseline/#ixzz2k9DVO8V6With E85 in the tank, however, the E92 computer upped the timing to help increase power to 321hp and 355 lb-ft of torque.
Do you know what the octane of E85 is?Ford says the car will run fine all the way down to E85.
