201 - 220 of 415 Posts
Discussion starter · #201 ·
Took it out for it's first drive and all went well tune is still in need of alot of work. this at my friends work, had to get my state inspection and emissions updated. Exempt of emissions due to mileage, less than 5000 a year. Everything underneath looked good with no leaks.
Discussion starter · #203 ·
Also got the last of the fittings i needed to install the lines going to the breather catch can.
Discussion starter · #213 ·
Small update, break in mileage is done and oil has been changed out. Replaced my Evolution wastegate cap with the newer adjustable cap and installed the 9psi spring. Working on the tune still.
Discussion starter · #215 ·
couldn't get the ID1000's to work correctly even with Toms help, so i got some 80lb injector from Mcnews and started over about 3 weeks ago. It's going pretty good now and hope to get some numbers soon.
Should of called topspeed ik they have id1000 on two focus
Discussion starter · #219 ·
called them, tried everything i could to get them to work. contacted sct, injector dynamics none of which offered much help. they said i could send the injectors in to have them checked over for free. i put the 80lb in and they are working just fine.
hmm wierd man, i run the 80 in mine and they work good too.
