my wife has a 06 with the lifetime filter and i've been trying to figure out how it works... doesn't it ever need cleaning? and what about small particles? does it filter them too?
[thumb] exactly why we switch to a serviceable filter setup.oh ok... i wonder how it doesn't get clogged right up in time... i mean i've seen how dirty the filter gets in my truck in just 15000kms and i can't imagine leaving a filter in for the car's life
Dont think its at 60k. Per our Sheduled Maintenance guide:ITs not only a solid piece of foam its a series of chambers then it leads up to the foam. so most of the stuff is filtered out before hand. It cost 300 bucks to replace that stupid box and your sapposed to do it at 60,000 miles.
60,000 miles
âť‘ Change engine oil and replace oil filter.
âť‘ Inspect tires for wear and rotate.
âť‘ Inspect brake pads/shoes/rotors/drums, brake
lines & hoses, and parking brake system.
âť‘ Inspect wheel ends for endplay and noise.
âť‘ Inspect engine cooling system and hoses.
âť‘ Inspect exhaust system and heat shields.
âť‘ Inspect steering linkage, ball joints, suspension and,
if equipped, half shafts, driveshaft and U-joints.
âť‘ Replace fuel filter (see page 47) (not required
for Fusion, Milan & Zephyr).
[B]âť‘ Replace engine air filter (not required for Focus).[/B]
150,000 miles
âť‘ Change Motorcraft Premium Gold Engine Coolant
(see exceptions page 46 and record page 48).
and, if equipped, half shafts, driveshaft and
U-joints.
[B]âť‘ Replace engine air filter (except Focus, see
below).[/B]
[B]âť‘ Check air filter restriction gauge, replace filter as
required (Focus only).[/B]
Code:60,000 miles âť‘ Change engine oil and replace oil filter. âť‘ Inspect tires for wear and rotate. âť‘ Inspect brake pads/shoes/rotors/drums, brake lines & hoses, and parking brake system. âť‘ Inspect wheel ends for endplay and noise. âť‘ Inspect engine cooling system and hoses. âť‘ Inspect exhaust system and heat shields. âť‘ Inspect steering linkage, ball joints, suspension and, if equipped, half shafts, driveshaft and U-joints. âť‘ Replace fuel filter (see page 47) (not required for Fusion, Milan & Zephyr). [B]âť‘ Replace engine air filter (not required for Focus).[/B]
They really think its a lifetime filter I guess. Has any '05-'07 owner had to replace theirs sooner?Code:150,000 miles âť‘ Change engine oil and replace oil filter. âť‘ Inspect tires for wear and rotate. âť‘ Inspect brake pads/shoes/rotors/drums, brake lines & hoses, and parking brake system. âť‘ Inspect wheel ends for endplay and noise. âť‘ Inspect engine cooling system and hoses. âť‘ Change Motorcraft Premium Gold Engine Coolant (see exceptions page 46 and record page 48). âť‘ Inspect exhaust system and heat shields. âť‘ Inspect steering linkage, ball joints, suspension and, if equipped, half shafts, driveshaft and U-joints. âť‘ Replace fuel filter (see page 47) (not required for Fusion, Milan & Zephyr). [B]âť‘ Replace engine air filter (except Focus, see below).[/B] [B]âť‘ Check air filter restriction gauge, replace filter as required (Focus only).[/B]
You may not be, I got that from a 2007 manual. So it could have changed from 2004 until 2007, especially since there weren't too many duratechs out in 2004.I drive and 2004 and im pretty sure in my manual it says 60,000 sorry if im wrong though.[ffrocks]
Im saving for an intake but since in 2004 there were very little 2.3l duratechs there arnt to many intakes out there. i want a short ram not a cold air. i don't want to hit a puddle and i get water lock.You may not be, I got that from a 2007 manual. So it could have changed from 2004 until 2007, especially since there weren't too many duratechs out in 2004.
Either way, I was happy to take mine out at 38000. Made a noticeable difference, wish I had done it sooner.
my 06 says 150,000 also.I'm looking at the short ram also.Same as you don't want to water lock.I got 93,000 miles and the gauge on the box is still in the green.
I've had my CAI on two different foci over a course of 3 years, all seasons, all kinds of conditions. From 24+ inches of snow to torrential downpours on 5 lane highways following semi's and I've never once felt the engine stumble. Now I don't try to run through huge puddles but I've hit plenty and never had a problem. If you have your drivers side tire well splash shield and bottom splash shield in place you wont have a problem unless you drive into a lake.. i want a short ram not a cold air. i don't want to hit a puddle and i get water lock.
Only the duratecs up to 07 have the non-serviceable air filters. Ford changed the design for 08-09 to include a serviceable filter.I have a 09 D2.0 and you can easily access the filter by popping off the clips on the air intake box. I suppose it wouldn't hurt to drop in a K&N high flow filter in place of the stock one. I wouldn't expect as much of a gain as a cold-air or short-ram though.
Except for PZEV, mine still has has the sealed airbox. Got a free K&N drop in filter from a friend, only to find out I can't open the stupid thing [bigcry]Only the duratecs up to 07 have the non-serviceable air filters. Ford changed the design for 08-09 to include a serviceable filter.
