81 - 100 of 161 Posts
wow! how the hell does it do that?? weird man!
man, physics or whatever this is, is amazing!
slow duratec, u now have more rep. you had 4 b4 i hit u with this.
  • Like
Reactions: slowduratec
lol, like what, the colts?? no way man...um...they just lost half their team lolz.
Discussion starter · #86 ·
lol. I wish I could figure out this multi-quote thing. I'm pretty sure I'm getting a set of OEM headlights from a fellow member on the forum. I've been a little busy so I haven't yet had a chance to modify the back cover plate to fit over the new D2S bulb and adapter cable.
Last Friday i threw both headlights in the car with my new D2S bulbs. I have no problems adjusting the headlights. I did not get any pics, sorry :-D but let me say they turned out perfect with the light throw.
So basically I need to get the front clear covers, finish modifying the back plates, get replacement 12V LED's and reseal the lights and im done!
Thanks to slowduratec who showed the pics of the washer mod for the TSX projectors. It all has to do with the way the light is reflected through the projector lens. However you do loose a little sharpness to the cutoff. You can add more washers for different colors too; more washers = less sharpness on cutoff. Plus I've got my projector housings sitting where I want them and do not want to remove them to do that mod.
to do multi-quote, you click that button on each post you wish to quote...they 'light up.'
then, go over to 'post reply' on the left. it will then let you quote them all.
Discussion starter · #89 ·
Update 06/07/2009
Ok today I started extending the back cover to the projectors to fit over the new bulbs and converter cable. Things are coming together slowly because I keep test fitting to make sure its right. I'm going to throw both headlights in the car tonight without the front clear covers and get a shot of the cutoff for everyone. And I think I'm going to tear apart my OEM headlights to get the clear covers from them (need to save money) :-D
Discussion starter · #92 · (Edited)
2nd Update for 06/07/2009
Damn, threw the headlights in without the front covers on and man im impressed.
I need to rotate the passenger projector clockwise about 5 degrees cause its a little off.
but enough talk time for pictures! AND the pictures dont even do the headlights justice, they look so badass!
General cutoff picture.
*Lost picture; will try and find them again.*
A rear view of the light spread, its actual wider but the camera didnt pick it up.
From the side so you can see the distance I was from the other side of the road.
Camera glare FTL!!!!
MORE CAMERA GLARE! The lights are crisp circles in person, no glare at all!!!!!
And this is from the drivers seat, as i said, the camera didnt do it justice.
Discussion starter · #99 ·
UPDATE 06/13/2009
I finished the back covers today. Used scrap pieces of aluminum and JB weld to make a really sturdy cover. Painted the white aluminum black for a cleaner look. It is also water tight (Besides for the holes at the bottom; water doesn't flow upwards) and heat proof up to like 600 degrees F.
Pictures!
Bottom with hole drilled for wires.
Inside, you can see the JB weld. Wow that stuff holds. its like a solid piece metal.
Tonight I'm going to throw the lights in the car one more time to check for rotational alignment and to make sure I still have enough up and down adjustment.
If all goes well tonight I will throw my stock lights in the oven to get the front clear covers and re-seal them tomorrow.
:-D
