41 - 60 of 76 Posts
Just a dumb question. If the endlinks are replaced, will I need to get an allignment? My car is doing this and I am going to replace them this weekend.
My car is now doing the same thing. It seems to only make the noise at very low speeds, or going over bumps at lows speeds. It's worse when making a left turn at very slow speeds. I jacked up the front driver side of the car and while the car was being lifted, there was the noise again (the rear suspension was making a similar noise while jacking but does not exhibit the noise while driving). I grabbed the sway bar end link while jacking up the car and I could feel the creaking in the end link (I had to reach over the wheel). If I applied pressure the link while lifting the car, I could reduce the noise, and the the creaking felt less. I am going to replace the link(s) and let you know if this fixed the problem. It's simple to check and just takes 5 minutes.
I have the same problem that it squeaks/grinds when I turn hard left slowly COMBINED with going over bumps.
Brought it to the dealer, the mechanic said that it was the rack and pinion! Does that make any sense? He did say that all the front end was tight which I can understand and agree with![bash]
Just don't want to spend $500+ to find out that this was not the problem! [vommit]
2003 Focus ZTW 40 000 miles. ALL stock.
I finally got a chance to replace the stabilizer bar links. The grinding sound was definitely the top bearing on the driver side link. The after market links I replaced them with are much more substantial and also include grease fittings and a life time warranty. The Ford links are no where near as good of quality and I wouldn't recommend replacing them with the same FORD OEM parts. Spend the extra cash. If anyone wants to do this, its pretty straight forward. You need only to jack up the car and remove both nuts on the link. The stud has a socket hex; thus you can use a box end wrench and hex key to remove the nut. I ended up using a vice grip (someone else already mentioned this) since the hardware on my links were a little corroded and I was going to toss the old links anyways. Use a little penetrating oil to loosen things up before trying to remove the nuts. I had to pry the stabilizer bar down a little on the driver side since there was a little tension on the link. Putting the new links, you can easily use the wrench and hex key. You can use a wrench on the opposite side rather then a hex key, but its a little harder to access. Anyways, I hope this is usefully for anyone with a nagging grinding creaking sound from the front suspensions.
What It Is And How To Prove It To Yourself
Mine is doing it too and I know EXACTLY WHERE it's coming from.
I just lowered mine. (Eibach Pro/Ford Racing Dampers) and I made one mistake which MAY or MAY NOT have contributed to the CAUSE. when I was putting in the front (assembled) spring/strut, I was on the bottom pusing it up throught the 3 (tri-pattern) bolt-holes, and a buddy was on the top spinning on the nuts for me. At some point lost when all was said and done, was torqueing down those nuts and I drove home (some 10 miles) with the those top, 6 nuts, only finger tight. I realized it after I got home and did get them tightened down good in the morning before moving the car again. BUT almost rightaway I noticed a soft grinding/creeking noise coming from the right front wheel/suspencion. First thing I did was tighten those same 3 bolds more. nada. BACK-2-THE-RACK ! Here's what I did to find it.
Put back up on the lift. (must be a wheels-hang-free-type)
Put a tall jack-stand under the lower ball-joint. The one I used had a foot-pump on it to push(nudge) the top up and down. (not actually a "pump-up" height adjusted by a spin-nut at the top-side)
Let the car down just enough to take the weight off the wheel, compress the spring just a smidge
(steering should be unlocked)
now the person wanting to know where the rub is coming from reach up and put their hand on the spring, as close the top as they can get.
NOW have a buddy grab the tire and turn it slightly, like maybe an inch or so, and gently push-pull it back forth (turning left/right-in/out). Repeatedly. At which point it should be crystal clear to the person who has his hand on the spring, where it's coming from. IN MY CASE the "grind-creek-rubbing" sound was coming from where the top of the spring meets the metal of damper-housing it sits in. BECAUSE apparently the bottom of the strut mount moves slightly and the SPRING WITH IT, WHILE the TOP side, tightly secured by 3 bolts DOES NOT move, (poducing the grinding you hear between the SPRING and top of the strut-mount the spring in mounted inside of.) So I took a cheap rubber-cement type brush and slathered and stuffed everywhere I could reach, with BEARING GREASE. This got me about 50% reduction in the rub/grind/noise. I'm told by one of "my guys",
1. It's nothing, it's safe to ignor, if you want, turn up the stereo and try to ignor it, it's not a situation that's going to deteriorate. Over time it MIGHT even FADE away.
2. If making it STOP NOW is all you're willing to accept, the only way is to REMOVE the sping/damper from the car, return to the spring-press, disassemble it, and lube up real good the offending-zone, then put it back together, which is likely to be an even bigger bitch than it was the first time with the spring now greased, since you're pressing it "into/on-to" the UNEVEN, slanted base. If you assembled your own, (or just watched it being done) you know what I mean. I'm currently in a holding pattern, waiting to see if the grease I already put up there ( I also blasted it with aerosol White-lithium) works in and makes for further silencing. If I end-up pulling it appart again I'm putting some-sort of rubber pad in there and if I can find it, wrap the end of the spring with plumbers teflon.
Autozone pn SL259 solved alot of the noise coming from my front suppension.
They call them Sway Bar Repair Kit, but they are just the endlink for the front sway bar. They come with grease fittings and are much more substantial than the original end links.
Yeller, I kinda like the sound of that, but I don't know if the part number you referenced for your '02, (I DID find it on-line) will fit my '07...
I was also thinking about one of those "Strut Tower Brace" things. one of our site sponsor-guys was marketing a really nice looking onna those... I forget who...
AND the REST of the noise?
I just ordered up the above. I haven't yet ordered something else, because I'm waiting to see how some other things I wanna try work out first, BUT, for those less CHEAP than I, you said this part "solved alot of the noise", I'm betting adding THIS would solve the REST of the noise: "Gabriel / Strut Mount - Front" (autozone part #142930)(nice picture) OR "Duralast / Strut Mount - Front", (autozone part#FD7190) (no picture). the Duralast one specifies "mount w/BEARING KIT", positively REEKS "grinding-be-gone" don't it?
I mean, if that's where YOUR grinding/creeking is coming from...
I'm gonna put these swaybar-support/control-arm replacements on and see what I got. If it's still not quiet enough, I'm pulling the strut mount out going back to the coil spring press and either lubing and or placing some sort of rubber padding between the spring and mount on the top side. Whichever is possible and still leaves it fairly easy to properly re-assemble the spring and strut-mount marrage. If by any slim chance after THAT I'm still vexed, I'll order up the strut-mount & bearing kit.
[wrenchin]
MIne does the exact same thing it seems to be getting worse.. I'm gonna go buy a couple cans of lithium grease and grease up the front sway bar and the spring mounts and see if that helps.. if not i'm gonna rebuild the front suspension..
First of all if it's really doing EXACTLY the same as mine, I can tell youright now no amount of grease or spray that's done without pulling it apart will do more than LESSEN but not stop the noise and perhaps buy a little time.
I reccomend you print out my description of how I traced mine and do it. IF IT's the SAME, (where the upper end of the spring meets the inside of the TOP-end of the strut mount), I was told to disassemble it and grease it. Well I don't know how sure I am I totally trust that advice. I think I had pretty f'ing decent access to that spot with my little grease brush and it seems Like it should have worked it's way in and it hasn't. after almost a week there's been no lessening it got a lot less right away and for a day or 2 but then it seems like it went back to like it was before. So here's my plan, I'm gonna wait for the parts I just ordered to arrive put them on. Sadly I don't think they'd fit your's or I'd reccomend. you can email AutoZONE and ask, (I had good luck with that) if that doesn't do it for me I'm gonna dissasemble that strut mount & Spring and LOOK at where I think it's coming from. If I'm right I'll be able to SEE the etching in the steel, then I'm going to find some sort of thin very dense, tough rubber padding/lining/gasket of some sort to line the spot where it's etching mabe even adheasive it into the strut mount and then GEASE the spring-contact side. In the event that works for a few days, a week a month and then resumes, I'm gonna get stinkin' BAKED ! ...and then I'll order up the strut-mount & bearing kit.
^^ Like i said i'm gonna try the swat bar end links if its not that then i'll do a rebuild and put the SVT kit and a HR front sway and re do all my bushing.. Its as simple as that.. NO more creaks and a way better handling car..
My stuff IS ALL brand-new. New Ebach springs and Ford Racing dampers, that came with new strut mounts. but i didn't see anything that looked like a "bearing" or "bearing kit" and when the problem's "grinding", "BEARINGS" sound good! I hope you can get the strut-bar links the part number referenced here are for '05-'06-'07.....
mine is an 03... and i'm SVT i cant afford a 1.5" drop my tires are too big.
yeah that's what I noticed... I wasn't reccomending any particular drop for you, But since you mentioned it, the Eibach pro kit I have is marketed-as a 1" (to 1.2"max) drop. Mine for sure didn't drop more than 1.2". I've got the stock 16" rims and P6 205/50's and I'm still thinking about 17" rims and or 205/215/60's on the rims I have now. (or possibly 205&/or/215/55's but last time I was chasing 55's they were pricer for the exact same tire (vs 50's) because it's an "odd" ((no pun intended) tire size))
My front suspension used to creak and make noise until last night when I installed my Moog front sway bar endlinks. Now my suspension is completely quiet and the handling is much better. I'm really lovin' it now.
those Moog "endlinks" sounds like the same thing YellerZX3 was talking about. Did they look anything like:
this? (mount vertically....)
or are you talking about a bushing set?
or,
[scratch]
because looking at the bushing sets made me think of something new. My car wasn't doing this before I put in the after market suspension. So, in order to get enough clearance to remove the assembled spring& strut mount OUT and the new one IN, I had to twist, against stong resistance, the swaybar, way down and back. Before I touched it, it was essentially neutral in terms of the pressuer it was applying "up or down" to the ball-joint/base of the strut-mount. BUT when shoved it BACK I remember it bothered I couldn't push it a little past, the desired stopping point then pull it back for a netural-resistance end result. Which meant, because of the stiffness of the bushing mounts, there was a strong DOWNWARD pull by the swaybar on the lower balljoints, and therefore the STRUT MOUNT as well. What effect this might have on associated "pressure-points" (such as the TOP end of the strut-mounts... eh HEM! [scratch] ) hmmmmmm!
i have an 08 zx3 that just started makin that noise a week ago wtf it only has 8000 miles on it
Aww, Screw That ! You need to seriously put that dealer's FEET to the FIRE.
and while you're at it, do eveything you can to be there start to finish. Watch what they do to T/S it and if possible watch them fix it. If necessary tell them why. It's Not because you don't trust them but so you can tell us what they did.
Important Update
OK, this applies to anyone who's noise started AFTER LOWERING or changing the SPRINGS for whatever reason or similar scenario.
Earlier this evening, down in my garage I took a good look at my old (original equipment) front spring/strut assembly still intact, in one piece as it came off the car. Guess what I saw? At the topside-end of the spring wrapped around the spring is a plastic/rubber sleeve of somesort. Exactly what it is, is not important. The FACT THAT IT's THERE, IS. BECAUSE I DON'T HAVE ONE NOW ON the same part as currenty assembled ON THE CAR. THE rubber/plastic piece is missing from exactly WHERE it feels to ME like the rubbing is coming from. This is more coincidence than I can swallow. I bought Springs seperately, and the DAMPER KIT also SEPERATELY. NEITHER CAME with any decent instructions. APPARENTLY whoever decided what needed to be in in the box with the DAMPERS assumed this part was either insignificant OR would come with the SPRINGS. Who ever decided what needed to come in the BOX with the SPRINGS assumed if the user wanted one they would re-use the old one. Which had the (some/any) instructions SAID THAT I certianly would have. I didn't ever even notice the f'ing thing untill this problem caused me to take very close look. SO IF YOU did what I did and left this little piece of plastic on the OLD spring, this IS YOUR PROBLEM.
[thankyou]
41 - 60 of 76 Posts
