For those who don't know:
Turbocharged @ 10psi
So today was a normal day just like any other. Hitting mild boost (5psi) city driving. Take the car home and on the way just felt like geting on it (10 Psi) 2nd gear pull to 60 then cruise. Got home running fine.
Next time I take it for a drive 4 hrs later, I hit 5psi and shifted and no BOV? Did it again then barley herd it. Instead of PPPAASHHHH!!! Its a wimpy fart just sounds like someone exhaling. Not the PPPAASSHH! sound. Also car studders in boost cuts in and out.
A/F is 10.0 - 10.3
J&S only shows 1 or 2 green sometime none (Its Random)
My theroy: Spark plugs are fowled causing the turbo to build boost but not the same volume of air to cause a PAASSHH sound? Thats the best theroy I can come up with and its not very convincing at all IMO.
Checked VAC lines to manifold/turbo/BOV/WG
Checked tailpipe for burning oil (None)
Checked MAF for water or dirt/oil (None)
Checked for BOOST leak (None)
Checked Air filter (Mild Dirty)
Im really out of Ideas and will be spending today at the shop because in 2-3days I have a dyno date & Remote Tune date w/Tom
HELP!
A/F is 10.0 - 10.3
HELP!
