torque mount. HELP!
1.1K views 10 replies 6 participants last post by  03zeteczx3
#1 ·
this weekend i installed energy suspension torque mount inserts. does anyone know the torque specs for this? my car has more than normal vibration at idle now. is this normal? i suspect its because i have over torqued the bolts.
#5 ·
well, if by press you mean bench vice, then yes lol! a press would have been the way to go but the vice works if you take your time. i took a 2x6 and cut a 3" circular hole in it, then used the peice that i cut out to "press" the rear bushing in. worked pretty good. make sute that you have the bushing positioned where you want it because once its in, its not gonna rotate.
dirtbrown, so this will all go away with time? i drive this car 120 miles a day and drivabliity is a huge factor for me. i dont want to shake the car to peices!
torque specs, anyone?
