I'm looking into getting a svt focus and debating whether to procharge or turbo it. Can i get some suggestions on what would be my best bet. If theres anything anyone would recommend doing please let me know.[loveff]
U really think at the same boost level 11 vs 11 PSI PW SVT can take PC SVT ?powerworks FTW!!
Naw I know the PC is more powerful but I'm like gonzorelic and like roots style over centrifugal...if you're gonna go centrifugal you might as well get a turbo.U really think at the same boost level 11 vs 11 PSI PW SVT can take PC SVT ?
^^^Installed PW with ZERO leaks and to what hole in the block do you refer?Get PW if you want a difficult install, oil leaks, and block with a hole in it.
Roots are NOT more efficient then centrifigal.....no way....I think reason is : The power is there from idle and going up until mid rpm....centrifugal has almost no bottom end, but HUGE upper power...therefore it's stupid to put into production car....they are not expecting you to drive 4000 up rpm all the time..(u will be over speed limit always ;_) I think that's the MAIN reason.... stock cars need to move in lower RPM, therefore roots or really small turbo.he means when it slings a rod thru the block... roots style is always more efficient means of power than centrifugal. especially twin screw. thats why you never see a vehicle manufacturer put centrifugal blowers on stock boosted cars. always turbo or roots.
