Where can I get a replacement? Ford says it's a discontinued part...
Says 21 in stock:Where can I get a replacement? Ford says it's a discontinued part...
Thanks!Says 21 in stock:
2000-2011 Ford Focus Master Cylinder 1M5Z-7A543-AA | TascaParts.com
2000-2011 Ford Focus part # 1M5Z-7A543-AA - Master Cylinderwww.tascaparts.com
Do you have a link for the hydrolic clutch line that goes from the master to the slave?Says 21 in stock:
OEM I am not sure where to find. This should work though:Do you have a link for the hydrolic clutch line that goes from the master to the slave?
Mm did it get the fluid all over the carpet lol. I just took my old hydraulic line to a shop and had them replace stainless hose with the original fittings. It cost about the same though.Where can I get a replacement? Ford says it's a discontinued part...
