1 - 3 of 3 Posts
The shift knob of my 2002 ZX3 disintegrated on the inside, and no longer stays put. I can remove it as easily as my hat. My question is if the metal piece pictured is part of the knob or the stick? And how would I replace the knob since most are screwed in?
306858
Ive not seen one fall apart to that extent but to remove the knob it simply unscrews - the female threads are part of the knob. So you will need to unscrew the inner part(s) from the shaft.
Junkyard knob is probably most cost effective solution.
Good luck
Paul
1 - 3 of 3 Posts
