What's up, name is Josh. Been around the forums for years but rarely post. Use the Focus forums more for info anyhow since I don't have one.
Figured I'd finally post my N/A build since I'm finally doing it. Cheaped out and just got the head milled .075". It's the max I can go and still maintain atleast .035" valve to piston clearance (Intake valve is at .037" with just a few * of adjustment, hope it performs well cause I don't have play).
Perfromance:
Crower custom grind cams (Focus Central race cams) Lift: .468/.454, RPM: 9,000+ (not going over 7,500 till I upgrade bottom end)
Custom PnP head
Head milled .075"
TONS of clearancing for cam lobes (see pics)
SVT Focus intake manifold
SVT Focus 63mm Throttle Body
30 lb injectors
Crower Ti Retainers
Crower Valve Springs
Focus Central adjustable cam gears
Energy Suspension HD endlinks in rear
3" Trubendz exhaust
3" in/out 18" long Yanaka Motorsports resonator
3" in/dual 3" out ebay muffler
Energy Suspension trans mount inserts
Transmission
Spec Stage 2 clutch
Fidanza Flywheel
Ebay Shift knob
TWM shifter
Rollers/Stoppers/Suspension:
17x8 Motegi TrakLite 2.0 wheels (14.6lbs each)
215/40/17 Falken Ziex ze512 tires
Summit Racing extended studs
Gorilla open end splined tuner lugs
Suspension Technique springs (1 coil cut off all around)
Nearly blown stock struts
21mm Escort GT swaybar
Stereo:
Pioneer deh-p6200bt head unit
Kicker 300.4 amps (x2)
Alpine 350.1 mono amp
12" Kicker CompVR sub
Kicker KS650 front speakers
Kicker 5x7 rear speakers
Exterior/Interior/Looks:
Smoked headlights (replacing with new Deop black housings)
Blacked inner turns (replacing with new Depo inners I'm blacking out)
Smoked tails
35% tint on side windows (drivers front needs redone)
40' of eDead80 sound deadening
Corbeau CR1 seats (Red)
Yet to put in/on: *In possession*
Crower Rods
American CF Carbon Fiber Cowl panel
Sparco Flash5 Steering Wheel
Wheel quick disconnect
150mph S/R Gauge Cluster
Precision Brakes 13" big brake Front upgrade
Precision Brakes 12" big brake Rear upgrade
Wings West lip kit
Schroth racing harnesses (debating)
Kicker RMB8 midbass (debating
Kicker KS35 speakers in custom pods (debating)
Perfromance:
Custom PnP head
Head milled .075"
30 lb injectors
Crower Ti Retainers
3" Trubendz exhaust
Transmission
Spec Stage 2 clutch
Fidanza Flywheel
Ebay Shift knob
TWM shifter
Stereo:
Smoked tails
Crower Rods
Wings West lip kit
