161 - 162 of 162 Posts
I would replace things like axle seals, crank and camshaft seals while the engine is out and easy to work on. Also, if your handy with a soldering iron, you can cut the gas tank harness under the back seat instead of dropping the gas tank to disconnect the harness at the tank. It s what I did. The whole swap is a lot of work, but worth it in the end.
Hi ghinote89, I just done my second engine and gearbox swap, my first swap I did just like your going to do but I used a euro engine and trans, another thing your could do is the water pump (unless mentioned) my last swap I did was auto to manual. Have fun and enjoy :)
