1 - 2 of 2 Posts
i have a 2000 zts with the zetec engine now its been pretty damn hot here in michigan the past few days(in the upper 90's) and its started to sputter when i go to take off from a stop sign. but then runs fine no problem and like i said before its only started to happen as it gotten hotter. oh and fyi the car has had a idle problem ever since that stupid intake hose when bad. but i replaced it and still kinda idles like crap. but if any one has some thought that would be great. thanks so much[wrenchin]
C2H5OH
Probably just the heat.
You could try running some Seafoam through the intake and see if that helps. Zetec's are somewhat known for oil puddling in the intake manifold and causing minor problems.
1 - 2 of 2 Posts
