1 - 7 of 7 Posts
Vince your Moderator
Does that head have cams, valves and springs?
Assembled Head
Fits 2000-2004 Focus ZX3 2.0L
CNC'd for flow improvement and includes 3-angle valve job
Cast from prime 319 aluminum
Assembled with 21-4N stainless steel intake and exhaust valves and production valve springs (tappets, cams and cam seals not included)
Intake valve diameter: 33mm, Exhaust valve diameter: 30mm
Chamber volume 47.7cc (Nominal)
Bare head weighs 28.3 lbs.
Production intake and exhaust manifolds bolt on TYPICAL AIRFLOW (@ 28" OF H20 DEPRESSION) AS DELIVERED
LIFT INTAKE FLOW
(SCFM) EXHAUST FLOW
(SCFM)
.050 38.0 32.8
.100 80.7 74.9
.150 119.1 109.1
.200 153.7 144.6
.250 181.0 167.9
.300 193.0 186.0
.350 204.8 188.5
.400 214.0 193.1
.550 220.3 195.2
specsPackage Dimensions:19.75 x 13 x 8Package Weight:35Part Type:Engine: Cylinder HeadsWarranty:Not AvailableInstructions:Not AvailableUPC Code:756122060124Catalog Pg:0
Dam, where were you 6 months ago, I have been looking for this head for 2 years. Unfortunately for you I ended up buying a low milage CFM Stage 3 Head.
1 - 7 of 7 Posts
