1 - 10 of 10 Posts
What controls endplay on a zetec engine? is it just the #3 bearing or is there something else?
the reason I ask is my #3 bearing is destroyed and also the crank on the thrust face.
The thrust surface on the crank is the only thing that controls end play. Get another crank.
Discussion Starter #3 (Edited)
I have a spare, but this thing was at the machine shop 5000k ago and the crank was polished, and now there is over 1/8 inch of endplay, probably more
not only is every bearing surface in the engine damaged but i fear the eagle rods are now out of round on the big end as i was able to see movement on the pistons when i tore it apart yesterday
I don't have any theory's as to how it happened but i do have a clutchmasters fx400 clutch. could that have caused this much damage ?
at least the bores and pistons are still good, its barely broken in and you can still see most of the honing marks
oh well back to the machine shop to see what they say.
307367
307368
307369
307370
Looks like clearance issues and or incorrect oil pressure.
Something seriously not right. Endplay is indeed controlled by #3 bearing and crank.
FF Affiliate
When you push the clutch your putting a LOT of load on the thrust stock Clutch the bigger you go with the Clutch the more thrust load you could have
Its unusual to see this happen but I have seen about a dozen or so over the years on the Zetec and about the same on the Duratec
A couple things
Are you bad to ride the clutch , rest your foot on it ?
The Clutch you have can you confirm your slave bearing is fully releasing ?
X2 to all of that. Wondering if some of those thrust bearings have the thrust on only one half, definitely not the better idea. I may be simply stirring up garbage in my brain. Does the lower main cap have a register to hold the thrust even with the top half? To keep both halves dead even.
Discussion Starter #8
A couple things
Yes the slave is fully releasing and I'm not riding the clutch.
What should the endplay min/max be for a zetec crank, i can't see to find that in the book I have?
.0035 to ,0102
FF Affiliate
I wouldnt go less then .005 and the MAX if the engine is running really doesnt matter , If the crank is out and there is ANY WEAR then junk it , No way I would use a crank with even .020 wear
Shim the crank sensor , it doesnt hurt anything and I have done it a few times for customers and there still running
1 - 10 of 10 Posts
