1 - 17 of 17 Posts
· Registered
Ok it started a couple months ago. It comes and goes and it also does it during idle and when i do hear it rattle i can rev it alittle and it changes with the reving of the engine. But like i said it comes and goes. Just lastnight i was able to get under the car while it was rattling and i found that its coming from around the oil pan. do i need to worrie?
· I.S.A.I.K.I.
I'm having the same issue that appears around 3000-3100 revs. I've tried to hold the throttle body open from underneath the hood to find the problem but it only happens when the car is moving. I hope it isn't my clutch starting to chatter...[:(]
· Registered
Discussion Starter · #7 ·
well i do know its not the clutch bc i had that replaced last year and if u are stand above the engine the sound is coming from the left handside "passenger side' if i had a heat sheild rattle wouldnt it rattle all the time?
· Registered
no not nessisarily, since certain frequencies cancel each other out, meaning at one rpm the engine will rattle like crazy and at another all vibrations will cancel each other out.
· Registered
Well, after 2 months of trying to figure out WTF!!!! was rattling under my hood, it turned out to be the Idler Pulley and Tensioner. The bearing was gone. I had no loss of power, the noise would come and go. It sounded it was on the top left, then top right, then from down below etc. I was F'N baffled by it. It took 3 mechanics plus myself to figure it out after 20 minutes of tinkering and listening. We initially thought it was the timing belt tensioner and when they started tearing it down they discovered it to be the Idler.
Check that out before you go diggin too far.
· Busy Monkey
2014 Ruby Red SE manual swapped
There's a stethoscope you can get specifically for cars, it has a rod on the end instead of a round thingy. You touch the rod to different parts of the car while it's running and if there's a vibration it will be louder as you get closer to the source. I'll try and post a pic tomorrow
1 - 17 of 17 Posts
