1 - 6 of 6 Posts
i have a boost controller...wastgate has a 7psi spring i try to turn up the boost but i get nothing..any ideas? sorry i was so breif
..your profile doesn't show engine upgrades. Is your engine capable of handling more the 7lbs??
ISn't that why you have a 7lb spring in it to only hold 7lbs?
Who's you BC hooked up? Either its hooked up wrong or its bad.
Also w/ a BC it don't matter what spring you have got in your WG. The point of a BC it to open @ what ever boost setting you want. When to BC opens then the WG will open. Only thing it that you cant go to a lower boost then the WG.
what brand bc? Electronic or Manual?
I'll check your connection of the boost controller, to make sure it is connected right. have you crank all the way up the BC and no change?? my 2Cents
Discussion Starter · #5 ·
its just a turbo x manual bc...and yes i have cranked it all the way and no change
1 - 6 of 6 Posts
