The jet for the wiper fluid does not work on my car. It started on my way up to Minneapolis where I have just moved. I thought it might be that the washer fluid was freezing in the nozzle so I cleaned off the ice and used a wire as probe to break up anything inside. There did not seem to be any resistance and the washer fluid in the reservoir is not frozen. A friend suggested that the fuse responsible for the washer fluid pump might be bad but the owner's manual does not specify which fuse is responsible for the pump. The closest I can find is fuse location 56 for front wipers. However, if the fuse was blown on that, the wipers wouldn't work either, but they do. I would like to try to solve this problem without taking it to a shop. Does anyone have any ideas what to do next? or what to look for?
