1 - 2 of 2 Posts
hi people i'm after a bit of advice got a 53 plate 1.6 ghia and the windscreen washers are not working the pump is pumping the jets are clean and not blocked as i have removed them from the bonnet and cleaned them out with a pin and compressed air, the problem is there is no water coming out off the pipe when you disconnect them from the washers and also the rear washer is not working, i think mayby the pump inside bottle is blocked with crap and if i can find them then i'll try and clean them out or replace them, i can see the top of the washer bottle inside the engine compartment but the rest off the bottle is somewhere inside the wing, so my question is how do you get to the washer bottle do you remove the outer wing or is it just the trim inside the wheel arch as im going to clean it all out before buying new to see if that sorts it out, any advice greatly appreciated or a fix would be better as ive searched through old threads and cant find anything about it cheers
brian
1 - 2 of 2 Posts
