41 - 47 of 47 Posts
I have factory remote start for that.
I got factory remote start to cool the car in the summer and warm it in the winter. However, it would be nice to be able to roll the windows and the sunroof up by remote if it starts raining.
It is called "Global open/close" feature as it was mentioned (press and hold open/close button on your keyfob for about 5 seconds to open/ close your windows at once, press one more time after if you want to stop them) and you can enable it either visiting and begging your dealer (it is just 5minutes thing) or using third party software, go to this thread "FoCCCus Central ECU Config Edit" and read, http://www.focusfanatics.com/forum/showthread.php?t=402666
Not sure if it can be enabled on lower trim level though.
Do not worry, you will need just standard ELM 327 (BT or USB). Focccus soft to enable this feature http://ford.xtlt.ru/FoCCCus/FoCCCus_0.8.2.zip and Forscan soft (http://forscan.org/home.html) to read/clear DTC (Diagnostic Trouble Codes) after (Focccus is not flawless...).
Read this documentation for Forscan, its pretty straight forward (http://forscan.org/documentation_13.html).
You can read the whole thread even though it is quite long, but you could try to enable some other cool features, you'll need modified ELM 327 ( to enable low speed MS CAN bus) though to do this.
Image is attached, option number 184.
Moonroof is not working though, windows only...
I can think of only one logical reason Ford chose to disable this.....it doesn't work right. Imagine if they discovered that the car was rolling its windows down uncommanded. Now imagine the liability when people start coming in with cars that were flooded in rain storms. Their attorneys probably didn't leave them a choice.
If the option worked reliably, it would be an asset and a customer satisfaction point. They had no other legitimate reason to disable it.
Too bad, because I really enjoyed this option on my other cars. I could roll my windows down from the commuter train, and it could be cooling off as I walked across the parking lot.
Actually, there is no logical reason to disable it, since this option was in European Focus for ages and it never happened that windows rolled down on its own. New NA Fusion has it too, btw.
41 - 47 of 47 Posts
