1 - 3 of 3 Posts
so basically I recently had the window smashed out my 2008 coupe. I finally got my glass in the mail today and I'm looking to get it replaced. The only problem is I can't figure out how to get my manual window crank off. Is there any secret or trick to this?
Any that aren't help on by a screw from the front have a spring clip on their shaft that clips onto the regulator shaft when pressed into position.
There's a special tool avail. that slides behind & pushes both sides of the clip to loosen it (cheap tool).
Feeling behind with a small screwdriver or two or thin metal strip can do the trick, often pushing the clip off entirely so you have to search for where it landed.
Simple once you see it, but hard to see when on.
1 - 3 of 3 Posts
