1 - 9 of 9 Posts
no those wont work because the front brakes on the svtf will rub on with 15's and i dont think 14s would fit. Your best bet is to get 16 inch rims and the tire size you might wanna look for is 205 55 16 they're a common tire size to find and you could get them pretty cheap
PARTS HUNTER
Is 100 the same as 108? NO. Is 100 the same as 100 yes. When u read a tire goes like this 215/45/17. 215 is the width of the tire. 45 is the thickness of the tire. 17 is the size of the wheel that the tire is made to fit. 205/70/14 the (14) means its for a 14 inch wheel which u don't have. Look for factory ford 16 inch wheels and put ur winter tires on those that's what 99% of the guys on here do where it snows. The Svt requires 16" or bigger wheels to fit around the brakes in front
PARTS HUNTER
U should make the grand prix the daily and the Svt the baby lol. The Svt is alot better
Discussion Starter · #7 ·
So if I go with the 16" factory rims, the offset is 52.5mm instead of 49mm on the SVT, thats ok then?
Also, I've actually sold my GTP, the SVT is now my DD and my baby
Discussion Starter · #8 ·
PARTS HUNTER
At least 2 sets of 16" ford wheel for sell in the bst forum check them out.
1 - 9 of 9 Posts
