1 - 11 of 11 Posts
Can a ST motor fit into a Svt that's a real question cause I'm weighing the options of putting a turbo in it with the access port and the install and it's a bit of money so do you guys think it will fit
Old Phart
The space is there, but IDK of such a swap complete to date.
The larger worry is how to arrange the wiring/electronics/instruments to mate with the SVT, if not a full installation of ST harness/components.
ST standalone harness from Ford Racing? It's available, but so far swaps have been into a MkIII with some adaptations or complete swap as needed.
8 DAY HOMECOMING
You would need to start here.
http://www.focusfanatics.com/forum/engine-transmission-swap/262509-duratec-swap-faq-answers.html
I don't believe they make an AP3 for the MK1 Focus yet. Just SCT with the XCAL. Since the ST is a duratec you need to check in how much is different between the dtec and SVT zetec.
It will probably be cheaper to buy a turbo kit for the SVT...would be unique if done for sure. But it has been out for 4 years and only recently was the ST put into a MK3 sedan.
Rebel Devil Customs if you are curious.
Old Phart
That's a great reference for the earlier duratec, and there's a VERY interesting thread right now in the Engine/trans swap section on an oddball swap - the OP used BOTH SVT & duratec PCMs to keep some SVT features.
One item for any duratec swap if you didn't know already - it wont bolt to a zetec transmission. Tranny, axles, and everything to go with are needed as well as the engine.
http://www.focusfanatics.com/forum/engine-transmission-swap/713481-svt-duratec-swap.html
8 DAY HOMECOMING
Couldn't you swap the bell housing and they would be the same correct? I was going to link that thread, but figured it didn't really relate to a certain degree. It confused me anyway.
Old Phart
That thread is VERY confusing, a rather unique solution that may never be duplicated.
I put it as a reference just to display HOW difficult it is to retain SVT gauges with a basic duratec swap. Intended to show that a current ST swap would likely need current gauge pack etc. unless you could do something similar using the stand alone ST engine harness/ECU avail. from Ford.
You COULD swap bell housings for the MTX-75 trans in a std. Focus, but with that being also half the trans case it means a full rebuild to make sure all fits correctly.
SVT uses the Getrag six speed, but I don't think the current one for the ST is any close relation.
Old Phart
Yes, brand & gear count is the same - but AFAIK it's an entirely different transmission built to handle the higher power of the current ST (and similar cars).
Yea I can imagine there are differences I was just merely stating it was a getrag used as well in the current model might make for maybe some similarities ????
Old Phart
One important similarity is that you need axles to match when using one.
MTX-75 axles don't fit the box at all.
w/ my magic bag
Best is to use a donor st if your up to it + fab skills. You have a svt, I'd just stick w/ the zetec & hop it up if wanted/needed.
1 - 11 of 11 Posts
