1 - 3 of 3 Posts
Hello,
I have a question, will 205/55/R 16 tires fit the front of my 2007 Ford focus? Or will there be an issue?
So mote be it
the question should be if they will fit, not if they will only fit on the fronts. You shouldnt run two different size tires on a car. yes they will fit, they are marginally taller, your speedo will be off a little at speed. I ran that size on a set of winter wheels, no negative effects. Ideally you want to stay within 5% difference between the oem height.
1 - 3 of 3 Posts
