1 - 5 of 5 Posts
Hey guys, I am having a problem with my right side low beam and right side brake light. Neither of them are working and I have been able to figure out that it is not the headlight, bulb or fuses. I havent done anything with the electrical lately and can not figure out what the problem could be. If anyone has a solution or suggestions that would be great. Thanks
ground wire probobly
i would go through your car and tighten down all the grounds you can find, or see if you can get ahold of a wiring diagram and just tighten the grounds that pertain to your lights.
could also be a short in wires some where
It also shut off the high beam light on the instrument cluster
like i said, find a wiring diagram, find where all 3 of those things link up at, and there is your problem.
Discussion Starter · #5 ·
Cool thanks, also its being used with projector headlights that have reversed the high and low beams, is there anyway to fix it
1 - 5 of 5 Posts
