1 - 3 of 3 Posts
welli got the wiring diagram from FF and got a new maf and put a cheater on the
1st o2 sensor.....i am still running codes but it is probally egr seeing as how i dont want it so i took it off but i am still having wierd starting issues the 1st couple of times it starts and dies instantanious then it almost dies but it "catches" it self and starts the idle kinda fluctuates between 600-800 only noticable if the hood is open and i get a flutter kind of a bucking almost around 2-3rpms when i am accelerating (not like fast acceleraton just normal) (not cruising either) at 3.5 it evens it self out and is fine got any ideas... maybe i dont have enought back pressure? my cat is hallow and i dont have an exhaust after that! or a tps issue?
i was reading up on the same problem with othere cars and the typical culprate was the iac valve being clogged mine would be 55,000 miles old, is this about right for a cleaning? is this the thing on the underside of the manifold? does it really get that dirty? and how do i clean it? or do i just buy a new 1?
1 - 3 of 3 Posts
