1 - 5 of 5 Posts
I need BOOOOST!!!!!!
title says it. at low rpms in a higher gear or at high rpms in a lower gear if i go to turn down a road or make a sharp curve and gas it the motor kills out. after warming up and having the S%!* ran out of it the problem seems to get worse. could this be a fuel filter maby? we dont have that ethanol BS mixed in the gas around here and i changed my filter a few months back but thats what it seems like. could it be more serious or more simple than that?
could be the fuel pump there is a big prob with them in the early focus models
Resident Curmudgeon
Fuel starvation is a big problem with all of these cars.
Fuel pump could be the source, but I would start with replacing the fuel filter.
If you have one that is dirty/clogged, then you will have a starvation issue.
But ONLY if you have less than 1/4 tank or so.
If this issue occurs when the tank is greater than 1/2 full, the it is probably the fuel pump.
To echo what others have already said, engine cut-out in a curve, especially with less than 1/4 tank of gas on board, is a classic symptom of the fuel-pump failure that plagued the '00-'01 models. You have a 100,000mi warranty on your fuel pump. See your dealer.
1 - 5 of 5 Posts
