1 - 2 of 2 Posts
My car started making whistling noises recently. I first noticed when I was inside the car on idle for around 15minutes while I was cleaning the dashboard. Then I started hearing a strange noise which changed to a low whistling sound then get louder and louder - it sounds like a tea pot kettle when it’s ready.
I followed the noise and found that it was coming from under the car a bit a the back maybe between the back tires. My initial thoughts are it could be a leaking hose? Because it sounds like air excaping from a tiny hole from a tire but it’s not coming from the tires and the sound only starts when the engine is on.
I tried opening all the doors maybe it’s a door seal leak but nope. I tried turning the ac on and off but still no change. It also happen when I switch the car on (turning the key ready for starting).
Anyone encountered this issue before? Its a ford focus 2014 Mk3
Here’s a video of the noise:
https://youtu.be/6K64l9N2FRU
Visiting Autoguysland to review best gps for truckers in order to find the best one for you if you concern.
Have you figured out the issue yet? Do you think the whistling noise is being made by vacuum leak? It could be worn or cracked hose.
1 - 2 of 2 Posts
