Honestly it sounds like you are spinning a tire, BUT - if that isn't the source - it's time to look CLOSE at the front wheel bearings & brakes.
Under that high stress, things can flex a bit & cause rubbing that isn't noticed otherwise...
Slightly "loose" bearing, brakes that are worn quite a bit, caliper that's hanging up somewhat could all come into play here.
I'm ruling out the CV joints, just because that would be more of a "clicking" noise in general... Though if you look under there & see a Shot boot, you have your answer....
Check it out, I'd like to hear what you see when you look in there more closely....
Luck!
