Thanks guys. The upper is the 2002 Grille I believe - year wise, I'm not 100% sure what it is but it is the one with the larger diamond pattern - the $89 one from CFM as mentioned before.
As for the turn signals that are no longer there, I just pulled the bulbs and tucked the harnesses under the bumper - turns out there is other wiring there that holds them up out of harms way - and the condenser - nicely. I think because, in the stock condition, there are three turn signals on each side (HID equiped that is), removing the bulb from the original grill signals does NOT result in a fast blinking signal.
The lower grill is stock. Hillaryd's grill does look pretty good and unique to boot with the outer surround color-matched. I considered it, but I have never done good paint work and don't have time to learn it, so, rather than F-up a $90 grille, I left well enough alone.
focusman6297 - Cool to hear you're local - somewhat. I know of two other fSVT owners in Ithaca - a yellow Euro and a Red '04 - but I've never really met the guys that drive them. I have to say, flying over the finger lakes has got to be a sight to see. [thumb]
