1 - 10 of 10 Posts
Was wondering if someone knew where the INtake Air temperature sensor wires are located within the MAF.The MAF has six wires, i just need to know which ones!!!
Thanks!!
FF #1 Most Wanted
Is this for the resistor mod or diode mod to trick the ECU to thinking that it's colder outside ?
I think its a resistor!
Discussion Starter · #5 ·
I appreciate everybodys input.I understand that what i am attempting more than likely does not work.I just wanted to try for myself, you know,. tinker a little bit with my car.If someone has any idea which wires does the "mod" hooks too, it will be appreciated.
I am telling you that the ECU will not allow for the mod to work for very long. It has been tried many times and never worked. Nothing you can tinker with will change that. No offense.
Discussion Starter · #8 ·
No offense taken focal.I just wanted to try this for myself.I am new to modding and whatever experience i can get or try, as long as its not anithing mayor, helps me on the how to of things.
Ok, well I will let someone else tell you, for the simple reason that I have seen it tried literally dozens of times and it doesn't work. I don't want to be the one telling you which wires to go splicing into for something that will not do anything.
i think it is the last 2 but if u have warrenty on ur car i wont do it cause it voided mine i didnt habe it in when i took it to the shop but they saw that the wires where split. so i wouldnt do it
1 - 10 of 10 Posts
