Behind the battery? i dont see it man. What lines go to it that i can see?Bolted to the firewall, to the right (driver's side) of center.
It just idles really rough and it has ever since i got it. The car shakes and vibrates stuff in my car. If the windows are down a little they vibrate and causes pressure inside the car its really messed up.I thought the DPFE was integrated into the EGR on this vehicle, but I'd have to run outside and check.
What problems are you having with your engine? DPFE issues are common with Zetecs, but I haven't seen that problem yet on a Dtec.
Is it bolted to the intake?I thought the DPFE was integrated into the EGR on this vehicle, but I'd have to run outside and check.
How can i check the mounts? will they look bad? can i wiggle the engine?The IAC is run off a voltage duty cycle.
Have you checked out obvious mechanical failures such as in the mounts themselves? Even if an engine is running very rough more often than not the mounts are enough to isolate the vibration from the passenger compartment, at least to the point that it won't vibrate the windows around...
There is a TSB out describing rocks getting wedged in between the subframe and rear engine mount causing a solid connection between the two and vibration. Check out all your mounts. And if everything mechanical is in good condition then look somewhere else.
What controls the voltage duty cycle? maybe its something before the IAC?The IAC is run off a voltage duty cycle.
Yes i can data log but my wideband is not installed yet. What should i log? i have some past logs.A visual look at the mounts usually suffices. Look for large tears in the bushings.
Its strange the car would run better with the IAC upside down. I had mine in upside down once and it never found its idle and threw a code repeatedly.
Do you have the ability to datalog?
The PCM. What happens when you turn the AC on? That's the simple test for the IAC. If the idle goes up, then the IAC is probably working.What controls the voltage duty cycle? maybe its something before the IAC?
A more common test is to simply unplug the IAC while the engine is idling. If the idle goes down, then the IAC was doing something.I tested the old IAC but i have checked the plug with a meter to see if maybe its not getting voltage or something to the IAC.
Manual transmission should be 700 rpm. For an Auto, I think it's more like 850 in N and 750 in gear.Maybe its in the SCT tune? what is a normal idle RPM?
Its not that its a low idle its a ruff low idle. Vibrates the car and just doesnt seem quite right.The PCM. What happens when you turn the AC on? That's the simple test for the IAC. If the idle goes up, then the IAC is probably working.
FYI: those Zetec problems with DPFEs caused missing not low idle. This is typical of EGR related problems. EGR closed= missing at low rpm until engine is warm, EGR open= missing at mid- higher rpm.
Yes it could simply be in the tune, but I would certainly check out the motor mounts especially the lower motor mount. Have you cleaned your MAF? What all have you done to your engine? Do you have a larger TB, for example?
