After doing the PCV delete i have a vacuum leak somewhere my idle is kinda high. Ive done the 200 mile relearn thing after resetting the ECU.
I didnt replace all the gaskets when i had it apart, i probably should of but they didnt look that bad. The brake booster doesnt seem like its all that tight but it really never did from the begining.
Anyone else had to hunt down a vacuum leak on this engine?
The PCV delete couldnt cause a vacuum leak could it?
I was going to use a small propane tank like for soldering water lines and hook a small flexable hose to it and use it to poke around some spots i think might be leaking to try and pinpoint where its at.
Is there a diagram somewhere that points out all the vac lines?
