1 - 4 of 4 Posts
Yes call me crazy but I don't think it's a bad idea finding rotors will be easy enough.
I want to attempt to change the bolt pattern on the hub from 4x108 to 4x100
I think with a drill press and some exhausting measurements this shouldn't be that hard or unsafe
I bought a pair of wheels they're 4x100 and some other mystery pattern
I mentioned a drill press but I probably wont be able to use one unless I remove the hub which is a PITA without a hydraulic press
but still determined I am. I will probably center the hub then use some sort of diy tool to draw a circle on the hubs and then with a caliper tool measure exactly the distance stud to stud for each new one.
has anyone re-drilled their hubs? I see there's a ready-made tool for this but it cost $275! that's more than the used enkeis I just bought!
hope links are ok here's the tool
as expensive as it is though I won't have to remove the hubs or anything just a very steady hand and a low speed drill. is there another cheaper tool for this? (darned 5 lugs get cheap tools!) cause I haven't seen one
FUBARCUS
It has been done. There's a guy that does the service and makes a jig to drill rotors that he will sell you so you can just buy the Focus rotors and redrill them each time you replace them.
  • Like
Reactions: cheap sleeper
I did exactly what you want. I re-drilled mine out to 4 on 100mm but left the original pattern so they are dual drilled. I did mine with a simple drill press and some hand tools.
1 - 4 of 4 Posts
